Handbrake Adjustment on Rear Discs
Just recently replaced the entire Hub assembly on a clio 3, 1.4 fitted with Disc Brakes and cant get the handbrake to work properly. The adjustment nut on the handbrake has been tightened up and the tension through the handbrake when you pull it on feels OK, but it isn't engaging on the calipers at the back. The levers on the calipers appear to be moving, but whether the travel on these is sufficient I,m not sure as I have no initial point of reference having not seen how far a working set should move!.
Any thoughts appreciated
regards
