having trouble removing drive shaft from passenger hub
Car  1.2 16v clio
need abit of help on idea's on how to remove the drive shaft everything is off but im having trouble removing the shaft its self as im needing to replace the wheel bearing ive tried wd 40 and smacking it with a hammer and a rubber mallet but im having no luck atall
is it safe to use a blow torch on the shaft? or am i missing something
the car is a 1.2 clio by the way if that helps lol
Halfords shock and lock works a treat as I did it on my passenger side couple of months ago, but when you rebuild it use copper slip will make the job 100 times easier next time
well the good news is i got it off but i also had trouble getting off the bottom ball joint but i just undone it from the wishbone this side is trashed im needing to replace the bottom ball joint , wheel bearing, top suspension rubbers all this just because i got tracking done and found the car to drive worse after i left the garage
oh i didn't mean it like i trashed it the wheel had quite alot of play also the bearing was gone beforehand but when removing everything to do the bearing i noticed the bottom ball joint was fubar'd
