FN2 Type R +MK6 Golf
Again i give you thee man in question...
They weren't fella, this was renault marketing. They also printed that the cup spec cars would have a different exalto. They didn't. It was the tyre that was used during the chassis signing off, there's very few sub 50k cars that have tyres designed for them. It would be silly, as then the tyre would only be optimum on that car, limiting the tyre's sales potential. Far better to have the chassis based on a tyre, therby expanding the tyres customer base.They were "developed" for the 182, and then were available as a mainstream replacment tyre in 2004.
Brad, are you a delivery driver? UPS?
Is it sheila?he cant answer hes been banned, and his name isnt brad!
Is it sheila?
He wont be replying.
I heard that was poppy c**k, that they werent actually designed for it?
Sure i read it on here?
Not so much heel toe, more like sole!A 106 GTi is what you need, you can pretty much stand on all the pedals with one foot at once tbh
Renault dont make the tyres so they cant make the braking performance better.
Heres a simple test. Find a non-abs car. Go out on a soaking wet road, drive at 45 miles per hour, then stamp on the brakes as hard as you can. What will happen? The tyres will lock and you will skid to a hault. I think this proves that in the wet, the limiting factor in stopping is the tyre.
So if its easy to see the tyre is the limiting factor in the wet, why so hard to see it in the dry? Do the same 45 miles per hour and stamp on the pedal as hard as you can. What happens? You skid.
The fact is the best way to reduce the braking distance is to fit a slick racing tyre. More grip = less braking distance. Why? Because the tyre is the limiting factor in braking. Not the caliper. Not the pads. Not the discs. The tyre.
So renault might have fitted larger discs to a 182. They might have added abs (which personally i think is s**t). They might have increased the servo. But when the limiting factor in stopping is how much grip you have, this is all irrelevant.
Hopefully he will be back.I enjoy his blinkered attitude to life...
Wear flippers. As proven on top gear.
big toe on the brake, little toe on the throttle - easy
I've mastered it in my works van, but can't quite get it right in the cup, my brake pedal doesn't travel enough to give me enough on the other pedal. My lasses Mini on the other hand is death when I tried it, with that stupid floor accelerator pedal.
The 182's one of the easiest cars to do it in. :S
Definitely!
Try it in a 360. Harder.
I find it really hard in any BMW, too. Bloody floor-hinged pedal.
