i had the exact same problem albeit on a different car thought it was a new engine i needed it turned out to be the waterpump they can squeal like a piggy and they can sound like marbles rattling about in a metal tin.so dont cack your pants just yet theres still hope!
water pump doesnt require cam belt off , only aux belt off. could remove the belt and run it see if noise goes away. doesnt sound good though get it checked properly asap ,
i would take covers off where the water pump is and have a look see if the pulley is wobbling about and if theres any leaking no matter how small from that area.no harm in looking try to pin point where noise is coming from first get it up in the air if need be get your head under the bonnet have a good look around.
FUEL RAIL Guard that chunk of aliminium on the front of the engine. The bolts tend to shear for some reason even though it's only bolted to the engine block, mines come loose twice.
had the stethoscope on today, noise is definitly top end around the central two pistons, i think it is cam followers or hydraulic tapets at this point.
