help ASAP with mk1 172 ecu
Car  172, Westfield
I have just fitted my new group n ecu and followed the instructions given exactly including the initial start up procedure to lock it to the car but the car just turns over and will not fire!
Any one got any suggestions to try before phoning company tomorrow I got it from?
I disconnected the battery and also had to disconnect the wiring plug from the fuel cut off switch so could it be possible I have to push this to re set it?
Immobiliser light not on at all when I attempt to start the car - The engine just turns over -
Looks like im car-less tomorrow right now!!
Just popped old ECU back in and starts first time
Can only assume that the new ECU is not being locked to the car?
(procedure tried as per K Tec - Turn ignition on till immob light out - once light gone out turn ignition off and await for immob light to start flashing again - once light started flashing fire up car as normal)
Anything else I can try? Any ideas appreciated!
Do you have access to a multimeter? If so, pull one of the injector plugs off and see what voltage you get a: with the ignition off
b: ign on
c: Cranking
You should get a small voltage when ign on, nothing when off, and pulses of 5ish volts when cranking
