HELP-had a deep scratch,polished it now paint smudg'd
Car  clio rs
HELP-
someone put a deep scratch on the bonnect of my 172cup, but after using a polish gun, it looked look the paint work is smudged, althought the scatch has slightly faded.
wat can i do, its on the front bonnet
HELP-
paint smudged sounds like youve burnt through the laquer mate. need pics to confirm.
will need blowing in or the entire bonnet painted
If you were using a standard rotary polisher, then as FM said, sounds like you've burnt through. If it was a deep scratch (ie: one you could catch with your fingernail with no problem), polishing would not have helped, so you would have had to get it painted anyway
If I were you, I'd look as this as an opportunity to get your stonechips done too.
sounds like you only used a scratch remover and not something after to buff back up to a shine
