help!! how do you adjust the camber and the toe on the rear of a megane coupe sport??
  monaco blue 172 ..
right having problems finding out how to adjust the toe and camber settings on the rear (both sides )of my mates megane coupe sport v reg(2000) feels unsteady round corners and slight bends as though it is crabbing /skidding. need help asap due to mot soon .. thanks in advance .......:dapprove:
Jaff.
Re: help!! how do you adjust the camber and the toe on the rear of a megane coupe spo
you cant. solid rear beam with fixed stubb axles. the camber is set by the axle. if its out the axle is bent. same with toe angles, if something is out of line theres something wrong with the axle.
only possible saviour would be the arms that are bolted to the chassis being bent or something making the beam not sit straight.
theyre notorious for being arse end twitchy anyway, get used to it or learn to master lift-off oversteer
