Help!!! I Want To Drop My Car
Car  phase 1 1.8 16v clio
Hi, I was wondering if anyone could tell me how many mm to the each spline on the rear tortion bar 1 pline = 35mm?????.
if so can i jus lower the front 35mm or has it got to be lower(to keep it level). and whats safe to drop im running 17's and want it as low as u can go. lol without major scrubbage, and will camber bolts on front help???? thanx:cool:
my 1.4 RT is -55mm front and 80mm rear on 17s :)
never understood the 'splines' method, do it the right way! ;)
Only need camber bolts if your having excess camber trouble.
1 spline is about 30mm I think.
You'll have to see whats Ok to drop the car different offset etc affects it.
so can i drop it even so if i drop bk 60 and front 60 it will remain level????? should do i would have thought so!!!
