Help needed (Essex/london) area
Car  172 Rep
Basically, stripping out the rear, and the two t40 bolts that undo the rear seats was a t**t and rounded off, don't have access to an angle grinder so it's anyone able to give a helping hand?
Same thing happened to one of mine so will be interested to hear your solution. So far I've tried plusgas + mole grips, next attempt will be to hammer on an imperial size socket then if that fails drill/grind it off.
Total b*****d job to do, I ended up grinding it off flat, centre punching then drilling and tapping.
I could probs help at the weekend.
Either really hammer another bit in, or grind two flat edges and use a spanner.
If I'd seen this earlier today I could have borrowed a grinder off site for you. Sorry.
