help / pointers on removing 172 cup brake master cylinder?
Car  PH2 RS172
as per title, it just a case of removing the 2 bolts holding the cylinder to the servo or does the whole servo have to come out? if the servo has to come out any pointers on that would be appriciated cheers
It's nuts you'll be undoing.
2 hold the vac pipe bracket on, then two hold the MS to the servo under those.
Once those are off, and your reservoir and lines are disconnected, it's as simple as wiggling it out.
Worth noting that you'll need clip to bleed it i believe. Real pig of a job.
Ah, if it's a cup setup then nope, you'll be alright.
Eezebleed pressure bleeder is worth it's weight in gold there still!
yes all sorted now thanks mate - defo was worth you noting that the 2 bolts that come off to hold the vac bracket on have 2 more bolts hidden underneath! didnt see them lol #crafty
