help? registering a cat D.
Car  RenaultSport clio 172 mk2
Hello,
I've been thinking of buying an 172 cup with minor damage. The car is a reg cat D. Seeing I am not really familiar with UK registration I wonder what needs to be done In order for me to be able to register it in Holland.
I allready read most information given on the VOSA and DVLA websites but haven't been able to work it out.
A step by step approach would do the trick.....;)
Thanks in advance for your help.
Jack
I dont think that because its a CATD it will be any different to register over there. Although i many be wrong.
pecan said:
There's plenty of Cups for sale, why not just go for a sound one?
At a rough guess maybe money?? Maybe wants to use ot at the ring... so previous accident damage is not an issue.
The car indeed is for rally purposes.
I bought a car from another country before but that wasn't near as complicated as it seems to be the case for UK vehicles.
Doesn't cat D means the registration is incomplete? If so, what needs to be done to get it fixed?
Thanks,
Jack
Nope,the registration will be fine, its only on Cat C cars that they need to go through a VOSA test or whatever its called.
D will be fine.
cat D's all you need to get it back on the road is tax and MOT obviously you will need the v5 - most cat d's come with them - Cat D's are treated as uneconomical to fix, this is due to dealers charging the earth to fix them !
cat C's need a VIC check to make sure all the paperwork is in correct form, like engine numbers/chassis tallying to paper worketc - Cat C's usually have chassis damage so unless you have a jig it would be uneconomical on a DIY jobby.
Also there are a few companies open round the UK that give your cat-d a really good look over, check welding, safety factors and the usual stuff, if it passes the CAT D is wiped clean.
i dont like this atall, this means you could see a nice mercedez hpi and it come fine, little do you know its once been upside down on the M1 lol
