Hi, I installed some Bilstein Coilovers today and the install went fine. However I discovered my car was running V-maxx Coilovers already and it would appear the top suspension bolt has a cam on it which I guess is a basic camber adjustment. The bilsteins just use a regular bolt.
The bilsteins were almost new, bought from here. I also replaced the top mounts with new kits as well.
When the car was dropped the ride height has only changed about 2cm either side. However the camber is hugely out. It's very visible. The car is undriveable. I don't have a Coilovers spanner and stupidly assumed that as the kits was used it might have been setup right. I think that car had solid top mounts whereas I am using the OEM top mount.
I will get the car to a specialist for alignment ASAP but is there anything I could do for now?
I think the top bolt being a camber adjustable bolt from the V-Max's kit won't help but it's well torqued up so I don't think that's the only reason.
I will have a pro set it up but would welcome some DIY help to get it a bit safer to drive to the specialist.
