HELP!!!!! WATER IN SPARK PLUG ON MY CLIO CUP
  caterham 7
Spark plug No2 is getting water in it and has got a little rusty has any one got any idea.
also was missfiring but have dried the plug and now all good
but wat do i do please help.......
  53 Clio's & counting
i assume wtaer has got in from washing the car etc mate,as long as u dry it out it will be fine
  Trophy Turbo :)
is the water in plug hole when the plug is in or water when the plug is removed???
Water can get in there from the air intake, Hence why a cold air closed induction snt a good idea when you go through a puddle
R-Sport.
  Mint 1*2's for sale-
Check your water tank for oil-
S
  172 Cup
dnt think so, i had oil in mine and id drained it of and is ok nw, (touch wood)
Wierd had oil in one of mine to and drained it last Wednesday put after a couple of hundred miles it came back so it was leaking from soemwhere.
A friend suggested I replace the rocker cover seal but as it was also around the top of the cover it must have come from above which indicated the inlet manifold gasket (a orange/red rubbery one). We haven't swapped it yet but I'm going to get the part this week and also new plugs, oil and oil filter to put things right.
I wonder if it's a more common fault than I thought ?
Nick
