HELP!!!!! WATER IN SPARK PLUG ON MY CLIO CUP
Car  caterham 7
Spark plug No2 is getting water in it and has got a little rusty has any one got any idea.
also was missfiring but have dried the plug and now all good
but wat do i do please help.......
is the water in plug hole when the plug is in or water when the plug is removed???
Water can get in there from the air intake, Hence why a cold air closed induction snt a good idea when you go through a puddle
Check your water tank for oil-
S
dnt think so, i had oil in mine and id drained it of and is ok nw, (touch wood)
Wierd had oil in one of mine to and drained it last Wednesday put after a couple of hundred miles it came back so it was leaking from soemwhere.
A friend suggested I replace the rocker cover seal but as it was also around the top of the cover it must have come from above which indicated the inlet manifold gasket (a orange/red rubbery one). We haven't swapped it yet but I'm going to get the part this week and also new plugs, oil and oil filter to put things right.
I wonder if it's a more common fault than I thought ?
Nick
