help wid coilovers
Car  K9 EVV
been on coilover for about 4 months think there great. running on 17 but my handling seem sh*te. get a bit of understeer wilst going into bends at speed. is there anything that i can do it make it better????
i might be lowering it at the front a little
mybe some spaces
will any of these work
need advise
Have you had th tracking chckd?
Also check tyre presure and tyre tread grip.
You could hgiher the back or tighten up the rear/ loosen the front dampers if there ajustable.
tyres are all fine. tracking has been done a few times i think i may need to lower the front. cheers for advice theo man,,,
the rear neeeds to be as low as possible
sod the tracking, what camber settings are you running????????
Quote: Originally posted by kev O on 06 August 2005
havent a clue how do i measure that?????
Id go and get it them set up properly otherwise you might aswell not have them
