Have I bought myself a turkey, or am I just worrying too much? you guys know more about clios than i do, so any advice would be appreciated....
I recently parted with a large wedge of (hard earned) cash
for a 95 N plate Renault Clio Williams 3. I wasnt unduly worried, as Id
had a Clio 16v previously which was pristine - well looked after, tidy and
immaculate. Sadly, my rip-off vision glasses were at the menders when I went to see the Williams... It looked great, sounded great, and all boded well,so I bought it.
The first two washes were the worst....
During the first, Id discovered the car had been resprayed.....badly. The
bottom of each front door were pretty rusty, and theyd painted straight
over it - no prep or anything. t**sers.
During the second, I was well pissed off. Both wheel arches were (apparently) immaculate, but on closer inspetion, the paint was peeling from the arch lip, with rust evident beneath. With some wire brushing, Ive got down to some of the bare (decent) metal, though it was extensive and got fairly far back towards the centre of the car. The idiot who resprayed it had even had the rubbery protective final coat appllied with the rust still underneath!!! The sills appear to be affected also, although (hopefully) not as badly - I havent had chance to check thoroughly yet.
When hoovering the car mats, I noticed the passenger side mat to be a little
raised. I probed further and lifted it up.... geez, I was upset when I found
what I found. The entire carpet and underlay were sodden.... totally wet. As
a hose-pipe demonstrated, the door was letting in water around the door
frame. I can only assume the dodgy paint-sprayer replaced the rubber seals
wrongly. I am at a loss as to how to rectify this, as Ive tried re-jigging
the rubber strip with minimal success.
Please, does anyone have any solutions to any of the problems Ive
described? My worry is that if corners have been cut externally on cosmetic
features, then they will have been on crucial mechanical matters also.
Although the engine blows no smoke, and runs ok. so far....
Sorry its so long-winded!
