help with brakes please 172 cup
  clio 172 cup 2002
i am trying to change the rear brake pads on my clio 172 cup do i need a special tool to push the piston back in the caliper? thanks
  172 cup
you need a caliper wind back tool but you can you a screwdriver a set waterpump pilers, by pushing the screwdriver against the disc in to the piston and wind the piston back with pilers it is often better if there is to of you.
MRBILLYUK
  FF Jeden Osiem Dwa
Cap off brake fluid reservoir then wind back clockwise like Matty says with a screwdriver . .
  Arctic Blue FF 182
Justin, have a quick look in your other thread you have started. Put a guide over there for you as well
