help with getting a softer ride!
Car  Clio Sport 172
Hi guys, needing some help on what to do regarding a softer ride!
Currently running 17s on 205/40/17s with a 30mm drop on these springs:
http://www.k-tecracing.com/show_product.asp?id=1152
The car looks spot on but i cant be doing with such a hard ride any longer. Ive heard good things about the Eibach sportlines, but would replacing the Ktecs above with these result in a softer ride? Or is a lot of it down to the low profile tyres.
Your thoughts are much appreciated, cheers
Tyres and the Springs Combined are making it a Shitty Ride so I would change Both,
16" with 45 Profile and some Eibach Springs :)
Cheers for the quick response ppl
Cant afford Coilys unfortunatly otherwise theyd be straight on!
How much of a difference do you notice between the Eibach springs compared to standard?
I can only really change 1 of the 2 for the time being, so which of these will result in the softest ride?
1) Changing wheels to 195/45/16s?
Or
2) replacing the k-tec springs with the Eibachs?
If you like your 17"s then I'd say Change the Springs 1st,
It's a much Cheaper option than New Wheels and Tyres.
Thanks for your advice Coby, going to order a set of Sportlines on Tues and see how i get on.
