Help with my factory stereo
Car  Half stripped mk2 172
Hi ppl, yesterday i fitted an induction kit, and disconnected the baery on my 172, and then when i tried to switch on the stereo but asked for a code. Someone told m i should find it in one of the manuals. Well I didnt, so please if anyone knows the default code ore somthing, that would be helpfulm if not th whole unit is coming out and fit some 45mm omori gauges instead!!! Vince
Hi Vince, theres a couple of people on here that can get a code for you, they need the numbers that are on the back of the unit. Post them all up and someone will be able to help you.
Cheers guys, I think to get the unit out for the numbers,I might as well take it out and bin it, and fit a 3-gauge din size panel from omori complete with gauges. Heheheh, too much hassle i reckon. But i will try the certificate, if i dont find it, its going to be my way then. Vince
probably quicker to remove it that route around for the code, write the code on top of the unit too.
