Helpful Keyboard Shortcuts
Couple of shortcut keys i use all the time on windows xp:-)
Alt + Tab ( fast way to switch between windows )
Alt + D ( Change the address in Internet explorer with out clicking )
Windowskey + D ( Minimize all windows so you can see desktop )
Windowskey ( Brings up start menu )
Ctrl + ESC ( brings up start menu )
ESC ( closes some windows )
Alt + F4 ( close the ones ^ does'nt )
CTRL + C ( copy )
Shift + insert ( paste )
Shift + home / end key ( selects the text to the left/Right of the mouse )
Enter ( Instead of clicking stuff lol:-) )
That's the main ones i use while useing XP :-) What do other people use. ??
Ctrl + z ( undo )
Ctrl + H ( Find + replace )
Alt ( on its own to get up to the file,view,edit,Ect)
Windowskey + D ( Minimize all windows so you can see desktop ) windows and M also works
CTRL + C ( copy )
Shift + insert ( paste ) CTRL + V is easier :) also CTRL + X for cut (all on same few keys)
use CTRL + L at work to lock screen, CTRL + E for explorer and ermmmmm cant think of any others off hand
Right now im looking for a Key shortcut to change ur writing so i can read it lol, I find insert and Shirt easyier as im right handed
Hold down CTRL key and use scroll wheel back/forward on mouse to enlarge/ reduce text in Firefox etc.:cool:
F11 - Full screen in both IE and Firefox. Might come in useful on your car PC.
Holy thread resurrection Batman!
CTRL + D copies the cell above to the cell you're in, or to the highlighted cells.
CTRL + ALT + arrow changes the screen orientation (a useful one for 1 April)
* CTRL+C (Copy)
* CTRL+X (Cut)
* CTRL+V (Paste)
* CTRL+Z (Undo)
* DELETE (Delete)
* SHIFT+DELETE (Delete the selected item permanently without placing the item in the Recycle Bin)
* CTRL while dragging an item (Copy the selected item)
* CTRL+SHIFT while dragging an item (Create a shortcut to the selected item)
* F2 key (Rename the selected item)
* CTRL+RIGHT ARROW (Move the insertion point to the beginning of the next word)
* CTRL+LEFT ARROW (Move the insertion point to the beginning of the previous word)
* CTRL+DOWN ARROW (Move the insertion point to the beginning of the next paragraph)
* CTRL+UP ARROW (Move the insertion point to the beginning of the previous paragraph)
* CTRL+SHIFT with any of the arrow keys (Highlight a block of text)
* SHIFT with any of the arrow keys (Select more than one item in a window or on the desktop, or select text in a document)
* CTRL+A (Select all)
* F3 key (Search for a file or a folder)
* ALT+ENTER (View the properties for the selected item)
* ALT+F4 (Close the active item, or quit the active program)
* ALT+ENTER (Display the properties of the selected object)
* ALT+SPACEBAR (Open the shortcut menu for the active window)
* CTRL+F4 (Close the active document in programs that enable you to have multiple documents open simultaneously)
* ALT+TAB (Switch between the open items)
* ALT+ESC (Cycle through items in the order that they had been opened)
* F6 key (Cycle through the screen elements in a window or on the desktop)
* F4 key (Display the Address bar list in My Computer or Windows Explorer)
* SHIFT+F10 (Display the shortcut menu for the selected item)
* ALT+SPACEBAR (Display the System menu for the active window)
* CTRL+ESC (Display the Start menu)
* ALT+Underlined letter in a menu name (Display the corresponding menu)
* Underlined letter in a command name on an open menu (Perform the corresponding command)
* F10 key (Activate the menu bar in the active program)
* RIGHT ARROW (Open the next menu to the right, or open a submenu)
* LEFT ARROW (Open the next menu to the left, or close a submenu)
* F5 key (Update the active window)
* BACKSPACE (View the folder one level up in My Computer or Windows Explorer)
* ESC (Cancel the current task)
* SHIFT when you insert a CD-ROM into the CD-ROM drive (Prevent the CD-ROM from automatically playing)
* CTRL+SHIFT+ESC (Open Task Manager)
