Hi. I've recently put a momo wheel and boss on my 172 cup. All working exactly as I wanted, airbag resistors in place, horn parping nicely...and then in true idiot style, I ignore the old "if it aint broke, dont fix it" rule...
I decided that I should definitely take the horn push off in order to cut off the earth contact wire that sticks out of the horn button that people have had short out and cause sparks.
Now I cant get the damned thing to parp again. Logic would suggest that the only thing I could have done is pull out one of teh horn wires somewhere. Well, I've jiggled them all and prodded and touched wires together and changed the fuse and it still wont bloomin well work.
I will take 12v to teh horn unit itself and the multimeter to the wiring it later, but in the meantime, does anyone have a suggestion as to what i've done and/or what I should check? I do notice the odd click from the squib every so often whe i turn the steering wheel.
Why cant I stay away from "fixing things until they're broken?"
cheers
cheers
