How do I remove a washer jet???
to remove the whole thing, I've been told that you have to remove the entire bumper!! But if you are just having problems with the little ball thingy in the end, pop it out with a blunt knife.....it worked for me....
yep I toke my bumper off because there is a nut at the back to tighten it...
Or unless your on about the windscreen washer jets?
Dave3141 said:
washer jet has a nut behind the bumper, bumper off job, piece of piss to remove though.
Not for the windscreen washers Dave. ;)
To remove the washers for the windscreen, first remove the black fabric lining under the bonnet. then there is a little nut you can unscrew then the pop up out of the bonnet.
Right....Had a look last night and there are no nuts!!! Although I did manage to loose one of the plastic clips holding on the soundproofing...
Looks like its held on with an odd shaped plastic lug...
Any more suggestions?
