With the key, and then undo the one iirc retaining screw and it'll come out. Its a bit more complicated than that but you need to turn the key to a certain position iirc! I removed one with a chisel and drill when I couldn't find the key!
Its a bit of a fucker, Im guessing the column is out of the car? Get it in a vice and drill as much of it out as you can, then theres a coupe of little bits which stick through to hold the barrel in place, chisel them out/down, I just kept going at it till it came out! Took a good ten minutes!
