How do you remove and refit the entire cooling system?
Car  Clio 182
Hey all,
Are there any guides or can someone provide a step by step as to how you'd go about removing the entire front end cooling system, please?!
I deffo need to replace the air condensing radiator, I may need to replace the water radiator too, but I'll see how it looks after the air condensor is out the way. I also need to remove and replace the fan, but this I assume is just bolted to the back of the water rad?
I've got as far as the bumper off lol so any helps or tips will be mucho appreciated.
Cheers :)
Slam panel, 4x bolts on the upper cross member, then 2x behind the acutal slam panel but infront of the air condensing radiator yea? Should it then just lift off?
Remove bumper, remove 4 13mm bolts on top, loosen 2 23mm bolts behind. Remove two 10mm bolts holding bonnet catch and remove that. Unclip loom from the front, Remove 2 10mm bolts holding upper rad brackets and lift the slam panel away.
