how do i change my spark plugs, i have a clio 182 ive took the engine cover off and theres 4 leads going into like a square box ?? anyone help me out or have any pics?
right, to change the park plugs, you need to remove the inlet. Undo the 7 iirc bolts from the font of the inlet, and 2 either side of the ign coil, then disconnect all the leads/hoses etc and it'll lift off. make sure you dont loose the inlet gasket!
Now you need a 6inch extension and a 16mm deep socket, this will undo the plugs.
