How to convert PH2 172 fuel rail to PH1?
I'm transplanting a PH2 172 engine into a different shell, and can't use the clio fuel pump/collector/regulator unit. How do I modify the fuel rail to use a regulator? It looks like I can fit the regulator out of the tank, so it should just be a case of drilling some holes.... How does the fuel return line attach to the fuel rail? More to the point, where can I get the parts required/ part numbers etc..
Andy
Radugns
  Clio 172 ph2
Hello old topic. Now it is hard to find a ph1 rail. Does anyone how can you convert a ph2 one?
Yarp
  Clio 182, E46 M3
Sorry to resurrect this guys, has anyone had any success doing this? I need one for my turbo conversion but Renault no longer supply or have stock of them and 2nd hand ones don’t exist
Radugns
  Clio 172 ph2
Well it is not that hard to create one, but you have to be very patient to shave inside ph2 fuel rail to obtain a nice surface so that O ring from regulator can seal. I can help you with some pictures of how it should look in the end. PM me
Yarp
  Clio 182, E46 M3
that would be great if you could. I’ll drop you a pm
