How to convert to hydraulic clutch
Hi, I have a friend who is in the process of fitting a F4RT engine and gearbox to his car. Apart from all the issues with the limited space in the engine compartment, wiring ecc. the question is how to fit the hydraulic clutch.
Can any master and slave unit be used, does it need to be a Megane unit? Does anybody have an idea on how to do this? Any pictures?
Thanks in advance
Jens
surely if he can figure everything else out he shouldn't be stumped by the clutch????
trial and error as with any conversion of the type... any similarly sized (piston area and travel) clutch master cylinder should work...
because the slave cylinder is part of the release bearing there for needing to have the hydraulics to oporate it.
