Nice little update
So first things first, massive thanks to
guysy I managed to pop the headlamp ball joint back together, doing this also made me notice the headlamp leveller shaft had been unwound so far it wasn't actually attached to the motor anymore, so two little fixes that took a very long time
My god it took some force to pop that damn ball joint back together though! I was very very pleased with myself until i noticed that where i had my finger inside the highbeam reflector it has like tarnished the silver reflective material a little bit and like rubbed it off :dapprove: tbh to anyone that doesn't know, you would never ever tell, but i know it's there and its really annoying because im trying to get this car as perfect as possible :dapprove: but anyway, onwards and upwards!
Much to the relief of myself and i'm sure most of the forum members, the tints are no more! I manned up and took a hairdrier and some stanley knife blades and made short work of it, no pictures as of yet because i still have a bit of glue to remove on one window, also need to attack them with the autoglym glass polish to make them 100% :boring:
I also popped to the local Citroen dealer and picked up these
Some nice mist style washer jets from a C3.
Out with the old
After a clean up with chemical guys orange degreaser, CYC clay and autoglym quick detailer ready for the new
All fitted, work great dead chuffed
Also while the bumper was off to sort the headlight i degreased all the inside of the bumper and all the slam panel and everywhere behind the bumper where grime builds up and also cracked on with the megane 225 washer jets
Spent a while rerunning the two hoses so they were all nice and neat and clipped into the bumper correctly, a little cable tie on each washer jeat nipple just to be on the safe side
Also removed the acoustic valve while the bumper was off, its much easier this way than attampeting it through the wheel arch, you can just about make out where i tucked the vac line and connector block
also nice view of the KTR induction kit
All fitted
look much better, very pleased
But they still don't work :banghead:
Then again, i did drain all the pipework of old washer fluid etc and may not have given them time to have even come on when i was trying to activate them never mind let it push fluid through the system and build pressure up etc, i was trying to pull the stalk and view them at the same time you see so i was getting soaked by the washer jets :rasp:
Oh and this turned up yesterday
I also managed to bag a mint condition rear bumper, in Iceberg Silver, for £75 should be arriving today hopefully
Also got a 3/4 plate arriving today or tomorrow too, just to join in the fun :rasp:
Thanks for looking :cheers:
