Identify my engine?
Car  Renault Clio Mk2 1.4 RT
Could any one tell me what engine this is. Its is a T reg clio 1.4 RT
Ive searched around but all the other 1.4 8v rt engines are different???
its an e7j
8v , im fitting one atm.
looks like e7j 634.
there are quite a few in the e7j series, same basic block, renault just added a few revisions along the way..
Same engine as mine, just mines cleaner :P
I really wouldn't bother fitting a k&n. Reasons for this is:
1, you have to buy the kit from k&n as it requires a plate to hold the throttle body down, because with out the air box on top it moves about.
2, Tried a cone filter on the end of the box with out filter in box and not much change in engine note.
3, I believe its around £90 for the k&n kit and you would get so much heat soak from the engine, because the filter attaches on top of the throttle body.
Pointless if you like to have a good mpg figure and also if you like to loss power.
Hopes this helps, you you do decide to get one post pics up.
i have the same engine layout. i noticed it seems to fall apart when you fit a cone air filter. Is it worth getting the plate to stabilise it or should i just leave it standard?
