In need of a panel filter..... ITG or Ktec?
Thrust-Rated
President of the KMAG fan club.
  F31 35d, Berlingo Na
As title states I'm looking to buy a panel filter to replace original one
Which is better?
Or they both the same?
I know ITG is more money but is there a reason behind it?
  DON'T SEND ME PM'S!!
Ktec is pipercross, which I prefer. ITG comes very over oiled, and they can be restrictive
  Lionel Richie
yep seriously, waste of time its not going to make your car any quicker by fitting a fancy panel filter
no one bothers cleaning them (its a hassle to do anyway!)
its all we use, even on the track cars etc, Sam's 182 did 192 bhp and 166 torques using a stock filter, they're not restrictive (unless dirty as f**k!)
  WRX
It will make about the same performance gain as letting that one you've been brewing off before you get in the car, instead of sharing it with passengers.
Thrust-Rated
You've lost me? :-/
  WRX
Get rid of excess "gas" weight,it would have about the same effect. Realistically,even if it made 2bhp you wouldn't tell.
Thrust-Rated
Ah I see. Silly me. Ye I get you
So basically
It's pointless?
  WRX
Well I'm a bit cynical to any mods unless they give you at least 20ish bhp you'd hardly tell any difference really. Others may disagree but that's my take on it all. Think the Top Gear Espace episode summed up mild mods perfectly.
Wow I could tell you some things about how that was filmed. Wasn't even the same engine in the end. Base nothing on that
  WRX
Just meant a load of bolt on bits basically mate, but yes I know they go mad for dramatic effect a lot, so could well believe it.
Thrust-Rated
Haha. Top gear is ridiculous anyway, most of the things they do anyway aren't realistic :-/
Ooo do tell?
car they bought was absolutely mullered, the engine made no power before they started so they pulled it out and put another in, which i think (long time since i was told the story) was a clio v6 lump, so higher output to start with. Pretty much put the whole thing to ****. There was more to it, but it's ages since i was told (by the guy that fitted the engine, and one of the most high regarded mappers in the country)
