info required
Car  clio sport 2.0
I require a new drivers side driveshaft but when I had a look under the car I found that the driveshaft passes through a part that has 3 bolts which in turn bolt onto the car. The bolts are missing and the part is moving about and making noise when driving. Was just wondering if anybody could help with the size of bolts needed to secure this properly??
Thanks for the advice I thought it should be bolted there! So U say its a joint so will the new drive shaft I have bought just join here then?
Thanks for the advice I thought it should be bolted on there. So when I go to fit my new shaft will it just join the other end in that joint then
The new shaft has the hole lot on it, joint into the box, bearing that bolts to the block, and the shaft itself
