Is there a fuse for the reversing lights?
Car  Clio 172 Cup
hey
i noticed that both my reversing lights are not working. I quickly browsed through the fuses section of the manual but couldnt find an entry for the reversing lights.
Is there a fuse for these lights? If so where is it!!!!
I noticed there are some more fuses under the bonet, near the battery - could it be in there?
Also, is there a fuse for the lights that light up the heating controls, as these have gone out.....again.
Could it all be due to a wiring problem or electrical fault?
regards J
the reverse lights aren't fused as far as I know, well not individually anyhow. Put windscreen wipers on then put car in reverse mate to see if your rear wiper auto-wipes. If it doesn't then I would say it's the reverse switch that's probably broken/dislodged.
The heater lights are on the same fuse (afaik) as your sidelights so if the sides are working then the fuse hasn't blown. They are 1.8w wedge filament lamps and a reet pain to change! lol!
your reverse lights are fused through one of the two fuses with a fan and what looks like a radiator behind it in the passenger fusebox think its one of the bottom ones.
controls some heater things air recirculation auto back wiper,auto wipers it depends on the equipment level so may be the answer to the heater light never know
check the sensor, its on the gearbox look through the wheel arch, they brake all the time
checked the fuses, but they all seem OK
i put the car in reverse, put the wipers on the rear wiper DIDNT come on automatically - so does this mean the switch/sensor has gone? Does this also explain why both the reverse lights are out?
j
