Is this the Correct 172 Ph2 damper??
Car  330 Ci
I've recently had one of my front dampers replaced, however until now hadn't looked at it.
Before i order one for the other side, can someone knowledagble confirm that its the correct damper for a PH2 172?
On fitting the garage commented that it had a different damping rate to the damper that was on there before - however unfortunately i have no idea what was previously fitted..
Part No: QAG178484
Is this the correct damper?
well it's non genuine. I've fitted that brand before and they've seemed decent enough. You shouldn't have an issue if you've replaced dampers as a pair.
Genuine dampers aren't expensive, and are made by KYB (kayaba)
Thanks for clearing that up, just wanted to check they hadn't fitted a regular clio damper.
Will get a matching one for the other side.
Sent from my far superior Android
I agree, cheaper then what I paid for the one in the pic too...£68! Shame I hadn't known at the time - still, no point dwelling on it :(
