Issues with the Connects2 and tuner list
Dip
Car  04 Clio 16V Dynamique
Issues with the Tuner list And Ipod Adapter
Bought the adapter, delivered the other day, only got round to installing it today. It turns out that it doesn't work. Recieved two packages first one is so that a from the HU a CD Changer can be fitted from there it goes to another interface where the Ipod can be connected. Firstly there is actually no response from the HU to say a Cd changer has been fitted, even left it disconnected for about 20 mins.
Does the Tuner List in an 04 Clio have changer capabilities?
Anyone know what the problem could be?
Thanks.
I'm pretty sure that you have to go into the menu of the HU and switch on the AUX IN function, then you can select AUX IN as the source and it will 'see' the virtual cd changer.
Any Ideas on how to get to this menu? I know hold down the Source button the extra menu comes up.
Im having exactly the same problem, I bought the connects2 from the same place also, im in contact with connects2 about the problem but they seem to think everything is wired up properly, so i'll keep you updated.
turner list does not have an aux in put, this kit plugs into where the cd changer does and i'm prettu sure oyu cant control the ipod through itm only charge it, you need to set the source to the cd changer so the disply just reads track 1 and cd1 and it should play through the speakers. well that s hou my connects 2 aux input works not too sure about the ipod one but they should be much the same.
all it does is take the ipods signal and they silver box decodes it inot the signal the cd changer generates which allows the speakers to play it. the volume controls work byt htats it in need to change track using thr mp3 player.
Well I contacted car audio direct to confirm that it did work with the Tuner list, they said it would. Connects2 on their site say it will work with it too. I just want it to work, Im really annoyed, its not the point that i had to wait 2 weeks for it to come, getting round to fitting it something that should just be plug and play doesnt actually work! There are 2 silver boxes, no way of checking that one of them could be faulty.
