itb help
  clio sport 182 cup
Hi.bought a set of jenvy itb's thing i need to no is.where do you put air temp sensor as crnt see a hole to put it into too.also where do you connect brake servo pipe too.vaccum one for brake servo.just crnt see anything.pictures will be helpful to what some of you have done.cheers.
neil a
Air temp sensor will go in the air filter backing plate.
You need to tap into two off the bodies and T them together to get a vac take off for the servo.
  clio sport 182 cup
Cheers for that.what if you done run a filter on the bodies any where else for air temp or not?
neil a
I would recommend running a filter with the position of the bodies on a clio, the last thing you want is dust or a stone getting soaked in.
I suppose if not you could cable tie the sensor on as close to the trumpets as possible.
