ITB Radiator Solution?
Car  Cooksport Fleet
Is there any radiators which are a correct dimension for an ITB'd 182 (off a different car e.g saxo?).
I too skint to shell out on a custom rad atm, so i need to find an air con rad and water rad which are shorter.
Any ideas?
look into volkswagon ones...
i think a polo one is similar, the only thing will be core sizes (ie you want it to hold the same amount), you pretty much need a custom rad to avoid any problems
im running a valeo one,
sits below sausage filter
was in our stock of renault parts so we think its off something like an old 5 or something, i will get more info.
350mm high
350mm high
are the mounting points ok on it?
you should make this more widely known, you could do a good business on here if you found the part number out
