CrippsCorner
A250 EbAMG
Hi I'm about to take on what is basically my 108k mile service, which I believe is the auxiliary belt change? Firstly... can I just confirm that a 'normal' garage should be able to take on this task without mucking it up? Obviously I understand why the cambelt on the Renaultsport's should be undertaken by a specialist, but with the auxiliary, I'm not so sure?
I've found in the past, buying things from K-Tec has actually worked out cheaper than letting the garage source stuff from Renault directly. Unless you know of somewhere cheaper?
Now is this all I need to give to the garage, on top of a regular service?
http://www.k-tecracing.com/show_product.asp?id=2421&appid=2
Or does the tensioner kit need changing as well? At this point not really interested in what people 'recommend' as such, but is this actually part of the service, or does this usually get changed with the cambelt?
http://www.k-tecracing.com/show_product.asp?id=2685&appid=2
Please let me know if I've forgotten anything else, thank you muchly :star:
