just changed pads and now hardly any brakes
daver1985
  172 + 555 scoob
right just changed the pads in my 172 when finished pumped the brake pedal everything felt fine until i just drove it there's no pedal until i pump it but then goes again straight after. really need to sort this out going wales tomorrow any advice would be grateful thanks
Daniel
  Whichever has fuel
172/182's are a pig to bleed.
You're going to need to do it again unfortunately.
daver1985
  172 + 555 scoob
so i need to bleed the brakes after changing the front brake pads? is this normal on 172/182's?
  172/1.2/E30
No need to bleed the brakes after changing pads. But you may have a leak in a brake line/hose/connection.
