Just removed my accoustic valve and installed a 76mm cold air feed pipe. The car sounds awsome now pulling off. where the car sounded good after bout 4k rpm be i removed, the car sounds beefy all the way up through the revs! I'd def reccommend it!
well easiest way i found 2 get at it is 2 remove ue passenger headlight and u should c just below. the pipe from ur airbox connects to it. all it does is make ur engine quieter up til abut 4k rpm.
I just removed the air feed pipe and sloted the new pipe onto the plastic bit whch clips in the air box. i would prob suggust getting a smaller pipe tho, maybe a 70m or bit smaller. 76mm was a bit 2 big. U wont notice any difference really. only thing u will notice is that the car sounds so much better now than before.
The valve sits at the end of the secondary intake pipe. Removing it still leaves the intake pipe in place. I did this last weekend on my 55 plate 182, at the same time as fitting a K&N panel filter. The noise difference is bearly noticable, the performance difference is only slight. It certainly doesn't sound anything remotely "like a beast" as the title inferred. If its noise you want just slap on a 57i but be prepared for a slight loss in power.
only sounds good when you put on a diff cold air feed pipe, i got a metal 76mm diameter hose. the old standard hose absorbs the sound cos its made of some kind of fabric.
