K tec exhaust fittings? Help !
Car  clio 172 cup
I bought a stealth 1 off the bay recently, but it hasnt come with any fittings, only the hanging brackets welded to the back box and centre section.
Does anybody have any pics to show me what I need?
I'm quite handy so I could knock / weld something together if I know what it should look like
I can get it put on this weekend then.
Cheers. Darren
you'll need a new cat->system flange gasket, the two standard hangers (probably best to renew the rear one), and two clamps of *correct* size (don't use u-bolt clamps that are even slightly too big as you'll oval the pipes)
edit. and some copper grease/exhaust sealant
Cheers,
The back box has a bracket coming off it with just a hole in it.
Without some sort of fitting its not going to fit into the rubber mount..
Maybe I could push a bolt through this and use that as a hanger??
Daz
It should have a length of steel through that hole on the back box bracket? Maybe try taking it off your standard one or yeah could try get one just like the standard?
If you use a bolt it will cut into the rear hanger rubber and not last very long!
