KENT CAMS.... How much
Car  Bumder With A Buffer
Kent high lift cams rally race spec.
For a Renault clio 16v or williams or a similar type engine.
Matching lifters and Blue fully adjustable pulleys.
How much would these normally cost and wot sort of power gains could be achived, being in mind that my car is already chipped, IKd and Magnex exhaust
Must be the ones on ebay. Best ask Bondy as I think he sells cams etc cheap. Guessing near 100 quid each for the pulleys at normal prices. God knows what for the cams and followers/lifters.
If you do a search on google I am sure you will find the cost. Sure the pulleys on their own are worth over 200 quid. Then cams and lifters, think this is classed a cam kit and probably worth about 600-700. Again google search would confirm.
Only worry is the chap selling says fits 16v or Williams and Id have thought the cams are different for both.
Renault Clio/Megane 1.8 16v
RN1601K(B)
1
£659.00
Renault Clio/Megane 2.0 16v
RN2001K(B)
1
£659.00
According to Larkspeed website. So 16v is a different cam to Williams. Hopefully seller on ebay will be able to tell you model of cam and you can check against Kent Cams website to see cam type.
