Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I had a knokcing when i accelerated hard i replace the engine mount under the battery tray friday it sorted the knocking but last night i noticed its started to do it again but not as bad as it was does anyone know what it could be. Cheers.
I will change all the mounts where abouts is the gearbox mount iv just brought the car so havnt a clue and also the engine top mount iv heard you can adjust them and also how come the knocking stopped for a few days. Cheers
Drivers side mount under the bonnet. Slacken it off, (x2 15mm iirc) then 'pull' the engine and mount as far as you can towards the front of the car. Retighten and test. Worked for me
So do you suggest slackenin the engine mount bolts then puuling the engine forward and tightening them back up once iv done this and it is still doin it will it be the manifold knockign on the bulk head.Cheers
Aye no worries. Very easy to do. I knew it was that mount for me, as my old cup never did it, untill the cambelt was changed. This mount has to come off for the belt to be changed. So it just needed re adjusting.
I looked at the mount and it was almost to the end on the bracket but i undun the bolts pulled the engine and bracket to the end of the adjustment done them up and tested it it seems ok now its weird as i only moved the bracket forward a lil and it seems to have sorted it im goin to change the rest of the mounts anyway cheers for that bud your a star.
ITS STARTED KNOCKING AGAIN WHEN I GIVE IT HARD ACCELERATION IV REPLACED THE MOUNT UNDER BATTERY IV MOVED THE ENGINE FORWARD WHAT ELSE CAN I DO TO STOP THE KNOCKING PLEASE HELP AND ALSO HOW DO I BECOME A CLIO SPORT MEMBER NOT A FORUM USER WB cheers
Mine's making a funny knocking noise from the back of the car. Its driving me nucking futs. Think its coming from one of the rear sturts, not sure though. For the sake of my sanity does anyone have any ideas?
ooooh result & ty 197 gaz
Thats been annoying me for months, 4x16mm bolts loosened, big hoik, tightened and job done - no more knocking.
mine was same, didnt do it till aux belt changed
Mine was doing this too when it got over here.
Like a sudden burst of grunting noises when accelerating in 1st or 2nd?
The dealers took it in and replaced the Drivers-side top engine mount under the warranty I got - now it just purrs like a cat :approve: a very big cat mind-you! lol
