There arn't any aftermarket bolt on dampers for the 182 with Cup pack apart from full coilover kits as far as i know.MCG said:what other dampers can you get which work well with eibach speedlines, which are compatible with a 182 with cup suspension?
Renault are talking rubish the 172/Cup use the same hub. It seems the none CUped 182 might use a differnet hub but I've not checked for certain. The Cuped 182 use a different hub 60mm spaced rarther than the 54mm spaced or the others.rwaterman said:Ive been to renault and they told me the part numbers for shocks and hubs for 172/cup & 182/cup both the NON cups 172/182 have the same shock and hub part number and the cups 172/182 also have the same part number!!!
Elite took a number from my standard shock and checked with koni directly if they had shocks to match the number they took from my car, which came back as a no show and basically told me there are shocks in developement for the 182 and they should be available in about 6 months approx.
I still dont know what hubs or shocks I have on my car??
Rob.
