KTR Uprated Engine Mounts - Lots of vibration
LiamR172
Scotland - NW
You need to slacken the mounts and start the car for 30 seconds give it some small revs let the engine sit were it wants. Tighten back up and they should feal great. I had no extra vibration with mine at all.
Just done a quick search on here before i fit mine, is this the correct way to fit the mount?
  Mec 350 slk manual
Fitted mine and have a bit of vibration would this be because the gear box mount bolts are going down through the mount with the nut put on under the mount , which may be touching the gearbox ?
