laptop hard drive replacement
Car  A4 Avant
I have a Dell Inspiron 9400 laptop. It's brilliant in everyway, I just wish now I'd specced it with more storage! So I now want to replace the hard drive. On my order it specs the disk drive as:
80GB (5,400 rpm) SATA Hard Drive.
I've seen this which seems a good price:
http://www.ebuyer.com/customer/prod...hvd19wcm9kdWN0X3Jldmlld3M=&product_uid=108779
This would be compatiable with my laptop wouldn't it?
If it is is there anyway of mirroring my existing Drive onto a new drive and then just plugging it in?
Cheers.
Should work as far as I'm aware. The only way to mirror it would be to put one of the drives in usb caddy, then use some mirroring software.
I just don't want to splash out £75 if it's not going to work!
What do you recommend to mirror it with if I put both drives in my desktop pc?
You don't necessarily need to put both drives in a desktop PC (they won't fit as standard without adapters, anyway!)
I use Acronis Workstation for this sort of thing; I've a cheap (£6) USB caddy, when I need to 'clone' a laptop, I just stick the 'new' drive in the caddy, then boot from the Acronis CD (which is all 'wizard' based) it allows simple cloning of a whole disk or partitions, with automagic re-sizing as it goes.
Once cloned, take the 'new' drive out of the caddy, swap it into the laptop, reboot, and enjoy.
yes they will plug into a desktop machine without a problem.
sata 2.5" laptop drives use exactly the same connectors as 3.5" sata desktop drives.
