LED Interior Group Buy....Poss
do these glow slightly when not on? like the other led group buy ones did?
so you get map light, boot light, vanity mirror lights? is that it? for a clio mk2
Yeah they do glow slightly and im unsure if theres a fix to it to be honest withough soldering resistors onto the connection plate...Form what i was told of the Mk2 that is what is required
Do you think you can get some lights for the reversing lights just noticed a thread that someone just done it looks mint well bright something like 24 leds in the bulb
any pics? and will they fit a ph1 1.6 16v
I will try and grab some pics tonight as the ones i have taken didnt turn out to well...As for fitting a Ph1 i think you would only require 2 Festons bulbs if you could double check that i will try get a price for you mate
Im just doing the group buy for the interior mate and do not want to start another one atm feel free to set one up yourself if you wish.
Gives a rough idea
what bulbs are in the interior lighting in an mk2ph3? i was told just normal 501's but they dont seem to work!
If its an LED one you fitted tur it round should work as LEDs are polorised only work one way round.
They a bright whitey kinda blue inreal?
If so then I'll have a set.
The festons go into the boot and glove box?
Just noticed in the other thread that interior/map light dnt fit in kit 2, can this be sorted before i get mine please ?
Your has already been sent out by the supplier im afraid....Im about to get in touch with him about this but i dont think he stocks 501s that are slimmer than the ones being sent out.....
Once you get the kit keep hold of the ill fitting lamp and i will sort womething out with you and the others
