Locking up rear brakes!
  Fiat Coupe 20v turbo
Im having a problem with my rear brakes locking up every time I apply hard/ish braking, Ive had the rear lowered recently and I presume that the valve thing hasnt been adjusted and my brakes think Ive got 3 passengers in the back, is this right? Is it easy to adjust? I need to sort this, my car wants to swap ends all the time and braking on corners is impossible!
  Gay Clio 172 phs1
Its easy to adjust mate. You need:
13mm spanner, 8mm (i think) spanner and a pair of grips
Mine was doing the same, until i adjusted it now its fine. :)
  TT 225
Ah, the wonderful rear brake bias valve... Always scares me since Adi ended up rolling his silver valver because of the same problem :confused:
yup, had this problem only slightly more severe! Think you need to remove at least one of the pads then just adjust the silver caliper cylinder (1/4 rotations, otherwise will be miles out). I just used a screw driver to adjust it too btw, pretty quick job.
  williams and trophy
so i saw on the run to the peaks mate........think i commented on it as well......lol
not having lowered mine mate i dont have this problem.but i would say jus doin as thejesus says wud be a temp cure and adj the bias valve woud sort for good..............not really messed with it so not sure
