Longlife exhaust on my 182
Car  Inferno 182 FF
Hi people,
I bought my 182 FF with a longlife exhaust have not researched exactly which but the receipt for a couple of years ago is 460quid and it has a transferable warrenty.
Any the problem is that it is drooping a little so while researching how many new brackets I need out of 4. (The two at the back the rubber is corroded.)
I discovered that the middle sections are not too well supported in fact I think one is not at all. and one just held with a circle of rubber as oppose to the bracket. it makes the exhaust look like it is bowing although very slightly in the middle.
I want to ensure it is as best supported as possible so should I just replace what is there currently or is there a better way. I am not sure if I can get a bracket in the correct place or not.
Does anyone have any experience of this. :p
Mostly looking for advice on how to sort the middle a bit.
Thanks,
Erm without seeing the problem ill struggle haha but I can tell you , there is two mounts at the rear and one in the centre section , they are normally pretty well supported at that ! The mounts are a common failure but that's normally the rear! Use the search bar and there's a bit of a mod for the rear with powerflex bushes !
there are 5 mounting points for a 182 exhaust. 2 at the back, 2 just behind the axle, and one in the center of the car
