Lots of movement in gear stick when backing off???
len_beach
Car  E92 M3,172 track car
I have suspected that my engine mounts may be a little shonky ever since I bought the car. It is due for its 48k service shortly at which time it will be getting new discs, pads, plugs, belts etc. but I want to nip this exhaust knocking, gearstick shaking issue in the bud at the same time.
Basically, I don't get any (noticeable) knocking/axle tramp on acceleration. I do get an exhaust knock when I start the car (could obviously be the w@nk exhaust) and when accelerating and backing off, the gear stick visibly jerks.
Are these signs of shoddy mounts, which should I replace or should I try adjust them?
cheers guys and gals.
All mounts Fred? What are the costs involved and anyone know part numbers or can I use GSF?
Just use Renault stuf infact you can just change the bushes as thats all that wears on them for hard stuff cheaply.
Dogbone is £40 engine £45 or so.
Cheers Edde. I take it that is £45 just for one mount? Do you have any part numbers for each engine mount and costs if possible?
Mechanical bits
Engine mount drivers side - 6000073669 £42.90 + vat
Engine mount rear stabiliser bar - 8200103802 £28.00 + vat
Engine mount pass side front - 7700795688 £30.45 + vat
Engine mount pass side rear ( under battery tray ) 8200089697 £20.31 + vat
They are old prices
most likely dogbone mount, but cud be upper or lower gearbox mount i have brand new spare set underneath my bed :) hehe
there just incase as i thought mine had gone and i could shake the whole side of the engine round after buying i went to fit and the garage hadnt bolted the top mount in hence it moving about so i bolted it up and its fine- i know there common for failing especially when having an uprated bottom mount (which i do) so there gathering dust until a knock arrises again
I'll try an adjustment then fellas and take it from there. From what I gather, uprated dog bones are not recommended due to movement transfer to other mounts?
They are good you'r just moving the weekness to more expensive parts new dogbones arn't that much.
