LY 182 FF, Steering issues, Help!!
Car  Liquid Yellow 182
I have got an awesome little Liquid Yellow 182 FF, but am starting to notice that the steering isn't as responsive as it should be? Also I think that it drifts left slightly when on the move?
Any ideas what this could be? Help would be much appreciated!!
Needs to be manually checked, Jack it up, with the wheel still on and tight, feel for play at 9-3 and 12-6, also worth checking (with wheel removed) play in the bottom balljoints with a leaver.
I'd say you'll have some slight play in the Track rod end, or inner.
Sounds like track rod ends mate - quite easy to replace but tracking must be done after.
Oh and advisable to replace both sides at the same time if it is the t.r.e 's.
